AnyConnect and Clientless SSL-VPN
Answered Question
Are there any issues in running Cisco AnyConnect and Clientless SSL-VPN alongside each other??
I am currently looking into adding AnyConnect functionality to an ASA that has currently configured to run Clientless SSL-VPN. The Clientless system will not be removed. I know how to configure it, I am wondering if someone has already configured this or if there are any issue with this setup?
Correct Answer by DialerString_2 about 6 years 10 months ago
I've tested this and you can do. I had both setup on my ASA.
Correct Answer by stephan.ochs about 6 years 10 months ago
Hi Daniel
It's a bit tricky if you want a granular authentication and authorization, but it works.
I'm running an ASA with IPSec, SSL Client and Clientless SSL.
Each of those VPNs with username/one-time-password and certificate based authen.
The main challenge is to build up a clean structure of Profile Maps, Connection Profiles, Group Policies and Dynamic Access Policies.
Feel free to ask further questions...
Stephan
Overall Rating: 5 (2 ratings)
Correct Answer
stephan.ochs Thu, 03/11/2010 - 05:01
Hi Daniel
Stephan
guibarati Wed, 03/27/2013 - 17:10
Hi Stephan,
Is there any document showing how to do it?
I have some anyconnect profile configured and I enabled clientless connection on them.
But when I access the URL https://"asa address" the ASA send me straight to anyconnect instalation.
If the profile is enable for anyconnect and clientless is ther a way to choose which way to connect?
Thanks!
JeromeTechie1 Thu, 03/28/2013 - 06:52
In group Policy edit > Advanced > AnyConnect CLient > Login Settings
Prompt user to choose
Related Content
