CUCME: what is the Normal CPU and Utilization
Mar 11th, 2010
What is the normal usage of CUCME CPU %, RAM % and CUCM also.
Is there any norm from cisco?
Paolo Bevilacqua Thu, 03/11/2010 - 07:10
Define normal?
Some customer do 1 call per hour, some other many hundreds.
Some use the router as VG only, others for many purposes.
Some use a big powerful router, some others a tiny little one.
Consequenly, there is no possible answer to your question other than: it depends.
iantra123 Thu, 03/11/2010 - 21:28
So,
I have to refer to the best practice for routers usage.
There is no way.
