VoiceMail Ports "Not Found"
twfredericks
Hello All -
Running CallManager 4.1 and Unity Connection 1.2
System has been running with no issues for well over 2 years. Recently (within the past 2 weeks) two VM ports out of the 24 are showing status "Not Found". I have reset the ports in CallManager and also disabled/re-enabled them in Unity Connection. Looking for some additional troubleshooting ideas that wouldn't require me to delete and re-create the integration. Thanks for your help!
Tom
Jaime Valencia
Have you tried rebooting the CUC server??
Sometimes a reset of VM ports from CCM just doesn't do it but a reboot of CUC works
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I deleted and recreated the ports in question and restarted the voice processing role in Unity Connection
and that fixed the problem - so I'm sure a server reboot would have fixed it as well.
Thanks for the suggestion.
Tom
