Cisco VPN Client Autoupdate question
Mar 11th, 2010
I need to upgrade all my vpn clients (over 100) from ver 5.0.03.530 to ver 5.0.06.160. 2 days I may attemps to do this with Cisco 3845, Microsoft IIS FTP and not succeed. My config is:
crypto isakmp client configuration group VPN
key xxxxxxxxx
pool xxxxxxxxx
acl split_default
save-password
backup-gateway x.x.x.x
netmask 255.255.255.0
auto-update client WinNT url ftp://vpnclient:[email protected] rev 5.0.06.0160
and output on autoupdate.log is
17:04:05 03/11/2010 : **Starting Autoupdate**
17:04:05 03/11/2010 : Autoupdate: Downloading from ftp://vpnclient:[email protected]
17:04:06 03/11/2010 : Downloading file ftp://vpnclient:[email protected]/binary_config.ini
17:04:06 03/11/2010 : Autoupdate: downloaded in: 484
17:04:06 03/11/2010 : Downloading file ftp://vpnclient:[email protected]/sig.dat
17:04:07 03/11/2010 : Autoupdate: downloaded in: 468
17:04:07 03/11/2010 : Autoupdate was unable to get file size out of http header
17:04:07 03/11/2010 : Autoupdate failed verifying the file
17:04:07 03/11/2010 : Autoupdate has send IPC to service
17:04:07 03/11/2010 : **Ending Autoupdate**
On cisco web site I can't find update-5.0.06.0160-major-K9.zip, onlu update-5.0.03.0560-major-K9.zip. I make my own file update-5.0.06.0160-major-K9.zip with
binary_config.ini
[binary]
LastMajorVersion=5.0.06.0160
LastMajorISFileName=vpnclient-win-is-5.0.06.0160-k9.exe
LastMajorMSIFileName=vpnclient-win-msi-5.0.06.0160-k9.exe
LastMajorMaxSize=11565908
sig.dat
SIG(vpnclient-win-msi-5.0.06.0160-k9.exe)= C5FA4D4413C1AB1664820B729A21DA1B
SIG(binary_config.ini)= F56FAF9348BCA634FA652DF015A44A61
and vpnclient-win-msi-5.0.06.0160-k9.exe
All files I place on FTP server
My signatures is maked with DiamondCS MD5 Utility from http://www.diamondcs.com.au
I realy need this solution to work, but I don't understand what type is default signature of files from update-5.0.03.0560-major-K9.zip.
When Cisco VPN Client connect I see following notification: Launch button is not active ?!
