Is bpdu filter enable best practice for access ports with portfast
Answered Question
Mar 11th, 2010
Could someone please confirm if applying bpdu filter enable on access ports with portfast enabled is best practice?
Darren
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Darren,
No it isn't, use bpdu guard + portfast it is more safe.
if you make a search in the forums you will find several issues caused by bpdu filter (possible bridging loops)
Hope to help
Giuseppe
Correct Answer by Leo Laohoo about 7 years 4 months ago
Personally, for an access port, I'd go for STP portfast and BPDU Guard enabled.  For trunk ports I have both disabled.
Correct Answer by Jerry Ye about 7 years 4 months ago
BPDU guard will error disable the port if it detect BPDU (another switch).
BPDU filter will turn off portfast if it detect BPDU.
If a BPDU is received on a Port Fast-enabled  interface, the interface loses its Port Fast-operational status, and  BPDU filtering is disabled.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstpopt.html#wp1095752
HTH,
jerry
Overall Rating: 5 (5 ratings)
Jerry Ye Thu, 03/11/2010 - 07:55
  • Cisco Employee,
Depend on your company's policy. If you want the port to be hard down when someone plug a switch into a portfast enabled port, then you should use bpdu guard. If your policy is to allow switch into portfast enabled port, then bpdu filter is a better approach.
HTH,
jerry
darrenriley5 Thu, 03/11/2010 - 09:24
I thought you could use both. BPDU guard to protect a port if it receives a BPDU so error disables the port.
Then BPDU filter simply to stop sending BPDU's from the port.
Correct Answer
Jerry Ye Thu, 03/11/2010 - 09:32
  • Cisco Employee,
HTH,
jerry
Correct Answer
Leo Laohoo Thu, 03/11/2010 - 14:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Correct Answer
Giuseppe Larosa Fri, 03/12/2010 - 02:14
  • Hall of Fame,
    Founding Member
Hello Darren,
Hope to help
Giuseppe
darrenriley5 Fri, 03/12/2010 - 08:33
Many thanks for everyone's replies. A CCIE engineer recently came and configured two Nexus 7000 switches for us and applied the spanning-tree bpduguard enable and spanning-tree bpdufilter enable on every access port which I found strange. Now I have confirmation I will remove the spanning-tree bpdufilter command from the access ports.
