Notes IMAP to Connection
Have Unity Connection 7.1.2 installed and tested IMAP connection from Lotus Notes full client which all works fine. Problem is that customer does not use the Lotus Notes FUll client on PC's, instead they use the Notes Web client. So my questions:
1. Does Notes Web client support IMAP function to Connection?
2. Or do you require a plug-in for this?
3. I guess if this is possible that you would need a media plugin for the browser to play back the message?
Charl
