traceroute in 6509
hi when i run a traceroute in a 6509 switch it is giving the below
details
BHUSD_6509#traceroute 12.164.240.161
Tracing the route to 12.164.240.161
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11  *  *  *
12  *  *  *
13  *  *  *
14  *  *  *
15  *  *  *
16  *  *  *
17  *  *  *
18  *  *  *
19  *  *  *
20  *  *  *
21  *  *  *
22  *  *  *
23  *  *  *
24  *  *  *
25  *  *  *
26  *  *  *
27  *  *  *
28  *  *  *
29  *  *  *
30  *  *  *
I am not getting a ip address or whatosever should come is that normal or anything we should do..
2 Accepted Solutions
Aaron Harrison
Post your config, and we'll tell you what's wrong...
Looks like you may not have a proper IP/DG combination, or proper routing configured...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes - if you don't have 'ip routing' enabled, then you need the 'ip default-gateway x.x.x.x" command configured.
If you have ip routing, you would want to enter 'ip route 0.0.0.0 0.0.0.0 x.x.x.x'
In both of these examples x.x.x.x would be the default GW for the subnet.
Aaron
Please rate helpful posts...
Aaron Harrison
Aaron
we dont have a gateway of last restort so i assume that that's y the traceroute is not working
Aaron
