SSL VPN Login Failed (Possible Bug)
Mar 11th, 2010
I configured the SSL VPN feature on a 1941 ISR running IOS 15.01M in order to use the AnyConnect client. However, after I open the welcome portal, where you have to type in a username and a password, I get a message "Login failed" before I even type anything. I can still log in, but this message appears for no reason at all. Do you think this might be a bug? I checked the Bug Toolkit, but couldn't find such a bug.
Any help will be appreciated.
pstefanovpavel Sun, 03/14/2010 - 06:12
I figured it out. I had the aaa authentication auto command, which allows you to login directly using the URL
So when you type the URL of the webvpn service without the
//webvpnauth?username:password part, it automatically tells you that the login has failed.
