Basic conceptual question on VPLS
Mar 11th, 2010
Folks, to my understanding VPLS is L2 VPN artchitecture. I thought that the idea here is that by using VPLS customers can gain connectivity to other sites using a layer 2 switch as the CPE(Customer Premise Equipment).
If that is the case, why this slide explaining VPLS shows the CPE devices as routers as well? Does it make sense? If have a router as a CPE shouldn't I be looking into L3 VPN technologies?
shivlu jain Mon, 03/15/2010 - 00:59
  • Silver, 250 points or more
May be Customer wants to use the same broadcast network with in the L2 domain.
regards
shivlu jain
www.mplsvpn.info
ozzyosbu1 Thu, 03/18/2010 - 07:31
VPLS is not limted to swicthes as CPEs, you can have Routers as well.
All the routers will be part of the same broadcast domain, as if they were in a LAN.
The SP cloud seems like a Layer 2 switch to the customer.
