WRVS4400N DNS Options for Open VNS Using Static DNS
Mar 11th, 2010
How can I get an ip address automatically from my ISP, but set a static DNS ip address for using Open DNS service? This can be done on many other routers including the Linksys home routers. Why doesnt it exist on WRVS4400N?
josruiz Fri, 03/19/2010 - 09:04
I was doing some reaserch on this router, notice the routers RV series are the ones that had this feature, however in the WRVS  series this option does not exist, you can get a RV series router and use the WRVS as a access point in order to get your wireless sinal.
waltcunningham Fri, 03/19/2010 - 17:25
Seems strange that the WRVS4400N doesn't have this feature. The models very similar. Seems like the firmware in the WRVS4400N should be updated to include the static DNS feature.
