Multi-DC Auto-RP with MSDP Design Question
Mar 11th, 2010
  • Bronze, 100 points or more
Most of Cisco design seem to recommend Anycast....then the latest DCAP came out which apppears to combine anycast, auto-rp and msdp but there isn't much sample configs:
I want to setup the multicast base on page 2-46.
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns743/ns758/networking_solutions_products_genericcontent0900aecd806c3a8c.pdf
I have 3 DC link by a MPLS WAN. On each DC redundant cores, I assume I setup Anycast with MSDP and do Auto-RP on the Anycast RP address.
Assuming Layer 3, on the downstream Distribution and Access, I believe I should setup a static RP pointing to the local DC Cores (ie ip pim rp-address 10.100.106.1 or should I just setup autorp like Edge on next sentence)
On the Edge WAN routers, I will setup "Ip pim autorp listener"
So is the above correct?
I have another question on the "override" option below
*******DC redundant Cores*****
interface Loopback105
description ****MSDP LOCAL PEER ADDRESS****
ip address 10.100.105.1 255.255.255.255
interface Loopback106
description ****ANYCAST RP ADDRESS****
ip address 10.100.106.1 255.255.255.255
ip pim sparse-mode
ip msdp peer 10.100.105.2 connect-source Loopback105
ip msdp cache-sa-state
ip msdp originator-id Loopback105
ip access-list standard AUTO-RP-CONTROL-GROUP
permit   224.0.1.39
permit  224.0.1.40
ip pim rp-address 10.100.106.1 AUTO-RP-CONTROL-GROUP (do I need the “override” option?)
ip pim send-rp-announce 10.100.106.1 scope 16 group-list AUTO-RP-CONTROL-GROUP
ip pim send-rp-discovery scope 16
