CUE change business Hours to quarters
Mar 11th, 2010
We have a customer that has implemented a UC500, and it works fine.
Only problem is that their normal business hours is from 8.15 in the morning. But when working in CCA, you can only set the business hour to half hours. Is there any way to change this setting?
Martin Abildgaard
Brandon Buffin Fri, 03/12/2010 - 06:48
Martin,
No, you can only configure the schedule based on half hours. I checked this from the CLI as well. It states:
  HH:MM        Hours:Minutes (Hours in 24 hour format; Minutes can only be 00 or
               30) e.g. 17:30
Hope this helps.
Brandon
Martin Abildgaard Tue, 03/16/2010 - 06:20
Hi Brandon
That what was I have seen as well.I was just hoping some one had a workaround... ;-)
Thanks for your reply.
Martin
Related Content
