WVC210 upload image
Mar 12th, 2010
Hello.
I have WVC210 camera and i need upload images in a period of time ( one each 15 min, for example ) not by motion detection. But i dont see this function in the actual Firm.
Its possible to develop this functionality in other versions, or are there any possibility to do that?
Thankas
Steven DiStefano Fri, 03/12/2010 - 06:01
  • Blue, 1500 points or more
Maybe this can help?
The Motion Detection setup does have a checkbox you can select that says X minutes before detecting the next event (range 0-15).
Direct hit?
SWVMS16 lets you configure a default or a custom schedule for recording.
-->Main Console: Define Schedule
And these allow Motion Detection or "Always Record" according to a single schedule...1 start time and 1 end time, per day (not multiple).
Steve
pluma1234 Sat, 04/17/2010 - 10:41
thanks for your answer, but other problem is the name of the file. If a want to upload to a web server the same name of the image For example "image.jpg" . the camera upload the name with date and number .
