unable to use gui
Answered Question
Mar 12th, 2010
could u tell me which all asdm image file will be compatible for pix 515e version 7.0
Hasmukh
Correct Answer by clark.d about 7 years 2 months ago
I beleieve the 6.x servies of ADM is for the 8.x IOS line. For 7 you need the 5.x series of the ASDM.
Dave
Overall Rating: 5 (1 ratings)
hyundai_mum Fri, 03/12/2010 - 03:39
i took asdm-603.bin image file but it gives me error while i set it as asdm file by cmd asdm image flash:asdm-603.bin
error "device manager image set but not a valid image file flash:asdm-603.bin"
could anybody tell me about the problem..................
Hasmukh
Correct Answer
clark.d Fri, 03/12/2010 - 06:22
Dave
hyundai_mum Mon, 03/15/2010 - 00:16
Hi Dave,
i took asdm-512.bin but still same error message comes
Hasmukh
clark.d Mon, 03/15/2010 - 06:07
Do a 'dir' and post here. Also post pix config.
hyundai_mum Wed, 03/17/2010 - 03:43
-dir- OUTPUT
-Directory of flash:/
6      -rw-  1767        06:11:31 Mar 12 2010  downgrade.cfg
9      -rw-  1966136     06:11:55 Mar 12 2010  image_old.bin
10     -rw-  5437440     06:20:02 Mar 12 2010  pix704.bin
13     -rw-  7495680     05:46:26 Mar 15 2010  asdm-512.bin
show run **OUTPUT**
FIREWALL# show run
PIX Version 7.0(4)
hostname FIREWALL
domain-name default.domain.invalid
enable password *******&%&%$#@ encrypted
names
interface Ethernet0
speed 100
duplex full
nameif P2P
security-level 0
no ip address
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
ip address 192.168.1.0 255.255.255.0
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-ipsec
ssh timeout 5
ssh version 1
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
Cryptochecksum:8ea961edd27fc9f07c64ee8d1b8411e0
: end
FIREWALL#
clark.d Wed, 03/17/2010 - 04:37
Where is the 'asdm image flash:/asdm-512.bin' in your config?? That needs to be set in config to tell Pix to use it.
hyundai_mum Wed, 03/17/2010 - 04:47
sorry i miss to copy that cmd from my FW
configuration
find entire OUTPUT here again
FIREWALL# show run
: Saved
PIX Version 7.0(4)
hostname FIREWALL
enable password *************&$&@# encrypted
names
interface Ethernet0
speed 100
duplex full
nameif P2P
security-level 0
no ip address
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
interface Ethernet2
speed 100
duplex full
nameif Internet
security-level 0
no ip address
passwd FF2EMMV7TaGoapHZ encrypted
boot system flash:/pix704.bin
ftp mode passive
pager lines 24
mtu P2P 1500
mtu inside 1500
mtu Internet 1500
ERROR: Command requires failover license
asdm history enable
arp timeout 14400
nat-control
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
username hyundaiadmin password PaxrDETtcTi9Dg/A encrypted
http server enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 15
ssh timeout 5
ssh version 1
console timeout 0
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
: end
FIREWALL#
