Please help !!!! How do i force traffic to use the uplink port?
Mar 12th, 2010
Hello
I am a network newbie so be gentle - can somebody help me with what I think is a trivial problem.  I have 2 switches (Cisco 3020) linked together via an uplink port and a number of servers (blades in this case) attached.  On each server/blade Nic0 is physically attached to Switch0 and Nic1 is physically attached to Switch1.
Network communication between all servers is ok as long as i hit the correct network card via the correct switch.. Eg from 10.10.11.203 if i hit a nic that is physically attached, it all works fine.  It is when i want to send traffic across the switches i have issues.  For example if i send traffic from 10.10.11.203 to 10.10.11.16 the traffic does not traverse switches via gi0/24, instead it insists on using gi0/19 which is attached to a switch (not uplinked) on another network which fails.
I need to somehow configure the switch(es) so that Switch 0 always attempts to use Switch 1 via the uplink before finally the decision is made to send traffic upwards over gi0/19 and onwards to other switches on the network.
Any help whatsoever is very much appreciated.
(1) Traceroute from (SW0) with SW1-gi0/19 enabled running traceroute from 10.10.11.203 to 10.10.11.16
Translating IP to mac .....
10.10.11.203 => 0022.649e.3ec6
10.10.11.16 => 0022.649b.dce2
Source 0022.649e.3ec6 found on SW0
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/19
Unable to send a l2trace request to 192.168.20.5. Timed out
Layer2 trace aborted.
(2) Traceroute from (SW0) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.116
10.10.11.116 => 0022.649b.dce4
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/16
Destination 0022.649b.dce4 found on SW0
Layer2 trace completed.
(3) Traceroute from (SW1) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.16
(4) Traceroute from (SW1) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.116
(5) Traceroute from (SW0) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.16
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/24
2 SW1 (10.10.11.31) : Gi0/24 => Gi0/16
Destination 0022.649b.dce2 found on SW1
Layer 2 trace completed
(6) Traceroute from (SW0) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
(7) Traceroute from (SW1) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
(8) Traceroute from (SW1) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
Switch 0 Running Config
version 12.2
no service pad
service sequence-numbers
hostname SW0
boot-start-marker
boot-end-marker
enable secret 5 $1$kDjk$GQ9ITEuCUwhGVFptPE2t9/
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
vlan internal allocation policy ascending
ip tftp source-interface FastEthernet0
ip address dhcp
interface GigabitEthernet0/1
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
description G5 Uplink
spanning-tree portfast trunk
interface GigabitEthernet0/18
interface GigabitEthernet0/19
description Dev Network Uplink
media-type rj45
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description X-Uplink Port
media-type internal
interface Vlan1
ip address 10.10.11.30 255.255.255.0
ip classless
ip http server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password Passw0rd123
login
line vty 5 15
login
end
Switch 1 Running Config
version 12.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$XR9L$VATn0pC6x/SxtOrhv1frA0
no aaa new-model
ip subnet-zero
ip address dhcp
shutdown
media-type rj45
media-type internal
interface Vlan1
ip address 10.10.11.31 255.255.255.0
ip classless
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
AxiomConsulting Fri, 03/12/2010 - 07:35
Steve,
I havent had a chance to fully read the configs and traces you posted, so apologies if my answer is incorrect, however it sounds to me asthough there are 3 switches in the network, the 2 x 3020 and the upstream switch (attached to gig0/19).
Spanning tree may have put the link between the 2 x 3020 in to block to avoid any switching loops, therefore traffic will go via gig0/19.
Please run show 'spanning tree blockedports' on the 2 x 3020 to see if this is the case, if so you can adjust the STP config according.
Kind regards
Steve
pingcrosby Fri, 03/12/2010 - 08:21
Many many thanks for this heads up..
Running ... the following commands - i got this information...
I have no idea if its relevant, however i see that gi0/19 has a cost of 23 for SW1 and 3023 for SW0
Does this shed any light -- sorry for my total lack of knowledge on this ....
SW0#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32768
             Address     0007.85e7.2f00
             Cost        3023
             Port        19 (GigabitEthernet0/19)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    49153  (priority 49152 sys-id-ext 1)
             Address     0023.05dd.5d00
             Aging Time  300 sec
  Uplinkfast enabled
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 3004      128.1    P2p Edge
Gi0/2               Desg FWD 3004      128.2    P2p Edge
Gi0/3               Desg FWD 3004      128.3    P2p Edge
Gi0/4               Desg FWD 3004      128.4    P2p Edge
Gi0/5               Desg FWD 3004      128.5    P2p Edge
Gi0/6               Desg FWD 3004      128.6    P2p Edge
Gi0/7               Desg FWD 3004      128.7    P2p Edge
Gi0/8               Desg FWD 3004      128.8    P2p Edge
Gi0/9               Desg FWD 3004      128.9    P2p Edge
Gi0/10              Desg FWD 3004      128.10   P2p Edge
Gi0/11              Desg FWD 3004      128.11   P2p Edge
Gi0/12              Desg FWD 3004      128.12   P2p Edge
Gi0/13              Desg FWD 3004      128.13   P2p Edge
Gi0/14              Desg FWD 3004      128.14   P2p Edge
Gi0/15              Desg FWD 3004      128.15   P2p Edge
Gi0/16              Desg FWD 3004      128.16   P2p Edge
Gi0/17              Desg FWD 3004      128.17   P2p Edge
Gi0/19              Root FWD 3019      128.19   Shr
Gi0/24              Desg FWD 3004      128.24   P2p
SW0#show spanning-tree blockedports
Name                 Blocked Interfaces List
Number of blocked ports (segments) in the system : 0
SW0#sh span root
                                        Root    Hello Max Fwd
Vlan                   Root ID          Cost    Time  Age Dly  Root Port
VLAN0001         32768 0007.85e7.2f00      3023    2   20  15  Gi0/19
And on Switch 1
SW1#show spanning-tree
VLAN0001
             Cost        23
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     0023.05dd.3880
             Aging Time  300 sec
Gi0/1               Desg FWD 4         128.1    P2p Edge
Gi0/2               Desg FWD 4         128.2    P2p Edge
Gi0/3               Desg FWD 4         128.3    P2p Edge
Gi0/4               Desg FWD 4         128.4    P2p Edge
Gi0/5               Desg FWD 4         128.5    P2p Edge
Gi0/6               Desg FWD 4         128.6    P2p Edge
Gi0/7               Desg FWD 4         128.7    P2p Edge
Gi0/8               Desg FWD 4         128.8    P2p Edge
Gi0/9               Desg FWD 4         128.9    P2p Edge
Gi0/10              Desg FWD 4         128.10   P2p Edge
Gi0/11              Desg FWD 4         128.11   P2p Edge
Gi0/12              Desg FWD 4         128.12   P2p Edge
Gi0/13              Desg FWD 4         128.13   P2p Edge
Gi0/14              Desg FWD 4         128.14   P2p Edge
Gi0/15              Desg FWD 4         128.15   P2p Edge
Gi0/16              Desg FWD 4         128.16   P2p Edge
Gi0/19              Root FWD 19        128.19   Shr
Gi0/24              Desg FWD 4         128.24   P2p
SW1#show spanning-tree blockedports
SW1#sh span root
                                        Root    Hello Max Fwd
VLAN0001         32768 0007.85e7.2f00        23    2   20  15  Gi0/19
jason.henderson Fri, 03/12/2010 - 15:50
Hi Steve,
I haven't read through the config, but whenever i see a port cost above 3000 i think uplinkfast.  Have you got uplinkfast enabled on one of the switches?
Jason.
pingcrosby Mon, 03/15/2010 - 04:36
Yes portfast is enabled on the switch
Should it be??
I thought portfast just allowed the switch to fail over via the uplink quickly.
Also i notice that on SW0 gi0/24 has the "orange" disabled light on ...is this relevant...i assume it should be "enabled" I have not disabled it, it seems to "disable" itself automatically.
Related Content
