IP Redirect
Answered Question
Mar 12th, 2010
I have a problem which i hope someone could shed some light on.
Currently I have 1 external IP address a  Webserver in the DMZ and a Exchange\OWA server in the LAN the router is a cisco 881.
We have a port rediorect rule to send all 443 traffic to the Exchange\OWA server in thye LAN.
I need to add SSL to the webserver and have ssl traffic go to both. Is there away to do this.
Correct Answer by paolo bevilacqua about 7 years 2 months ago
Yes. But for one server, you will have to use a non-standard port.
If you do not want to use non-standard port, you need more addresses from ISP, or move servers to hosting facility.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Fri, 03/12/2010 - 05:41
  • Hall of Fame,
    Founding Member
