Do I Need router? VG224 with IOS, DSP packed!!!
Mar 12th, 2010
I am looking to connect analog phones on different branches. If i purchase VG-224 , it have IOS, i can define dail pattern, it have some builtin DSP's.
Now a question is raised that why i opt for router at first place if every thing is cater by my voice gateway. Whats your experience as i have never implemented it. Can i do routing, QOS and other voice feature or it. Or put in another way what additional feature i will get if i purchase router.
Overall Rating: 4 (1 ratings)
Aaron Harrison Fri, 03/12/2010 - 07:17
Your VG224 is a Voice Gateway - it's really not meant for anything other than terminating FXS lines. You could consider it more of an endpoint than a router really.
You can't add or remove interfaces to it, and the IOS that's available for it will be limited to voice-type features.
A router will be capable of doing everything that the VG224 does, plus a huge amount of other stuff - so for a remote branch an ISR could be your WAN gateway, PSTN gateway, SRST fallback, and a lot of other things such as application compression etc..
Aaron
Please rate helpful posts...
omair.siddiqui Fri, 03/12/2010 - 07:31
Thanks your response is very helpful in general. Actually i want to educate my customer who is demanding this solution. I understand that NO CME/ No SRST No WAN itnerfaces, But other than what are the specific feature i can inform him ?
Aaron Harrison Fri, 03/12/2010 - 07:34
That's a very open question, and the list of things it can't do would be very long. I would take the other approach:
1) Ask your customer what they want something with 'Voice Gateway' in it's name to do.
2) Check on those specific features, or ask back here..
Aaron
