Default username for WCS database
Mar 12th, 2010
Silly question, but what is the default username for the SQL database that runs in the background, our WCS server crashed recently and when I try to restart the WCS server it says the database cannot authenicate. I've found the password reset command for the database. I'm guessing its root.
dennischolmes Fri, 03/12/2010 - 14:42
  • Gold, 750 points or more
I havent checked lately but I think it is root and public.
sgilfrin1 Mon, 03/15/2010 - 03:05
Thats what I thought it was. I think I'm going to have to bite the bullet and run a password change.
Lucien Avramov Mon, 03/15/2010 - 14:23
  • Red, 2250 points or more
Yes, please use the password change procedure. It takes just a few seconds.
To be on the safe side, run a database backup prior to it.
Once the password is changed you have nothing else to set in WCS, WCS is updated about the new password.
Lucien Avramov Mon, 03/22/2010 - 18:24
the user is ''dba'' and the pasword is whatever you set it to using the dbadmin command.
I will cover advanced database troubleshooting during my webcast on April 20th. Stay tuned on the ask the expert page / main page. To signup go to www.ciscolivevirtual.com
Trending Topics - Security & Network
