SPA8800 RTP port
Mar 12th, 2010
I'm having trouble getting audio to work on an inbound PSTN-VOIP call.  I believe the problem is that the SPA8800 is giving an odd number port for it's RTP port.  The odd number port is confusing the voip software I need to use which receives the call.  RTP ports should be even with the RTCP port being the odd numbered ports.  Is there a way to force the spa8800 to assign ports correctly?  Thanks.
nseto Wed, 03/17/2010 - 15:08
You can see the options available in the SIP tab, under RTP Parameters.  It allows for a range of ports but not even vs odd.
FlyingDoctor_2 Tue, 04/05/2011 - 07:23
RFC3550 -  RTP SHOULD use an even destination port number and the corresponding
   RTCP stream SHOULD use the next higher (odd) destination port number.
SPA 8000 suffers from the same bug
I would not hold your breath waiting for a fix
Related Content
