Create DMZ on a Zone Based Policy IOS Firewall
Mar 12th, 2010
Dear All,
I have created Zone Based Policy IOS Firewall on Cisco 3600. I created it using SDM.
While creating I used Basic Firewall wizard.
However After few months it appeared that I need DMZ zone (DMZ is not created using basic firewall wizard, but only with using advanced fw wizard).
My question is if it is possible to create additional zone and make it work like DMZ without starting whole wizard for creating advanced firewall from the beginning.
If it is possible I will appreciate any help on how to do that.
Thank you in advance
Overall Rating: 3 (1 ratings)
Ganesh Hariharan Sat, 03/13/2010 - 00:42
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Dear All,
Check out the below links it will clears your query !!
http://www.cisco.com/en/US/prod/vpndevc/ps5708/ps5710/ps1018/prod_configuration_example0900aecd804f1776.pdf
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a0080a0eac7.shtml
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Related Content
