WS-SUP720-3B and 10G compatibility
Answered Question
Overall Rating: 5 (4 ratings)
Jon Marshall Fri, 03/12/2010 - 16:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
Overall, I am trying to find any information if I need to upgrade my sups to 720-3Cs or can I cost save and upgrade the IOS on my 720-3Bs.  Would a 6716-10G line card be compatibable with a 720-3B?
You will be fine with a Sup720-3B. From the same doc i sent a link to -
Q. Which supervisor engine supports the 16-port 10 Gigabit Ethernet module?
A. The 16-port 10 Gigabit Ethernet module works with any Virtual Switching Supervisor Engine 720-10G or Supervisor Engine 720, including VS-S720-10G-3C, VS-S720-10G-3CXL, WS-Sup720, WS-Sup720-3B, and WS-Sup720-3BXL.
Jon
comeback313 Mon, 12/07/2015 - 01:25
sh version
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-IPSERVICESK9-M), Version 15.2(4)S3a, RELEASE SOFTWARE (fc1)
Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1407B6J0
Does it support for below line cards
WS-X6708-10G-3C=
C6K 8 port 10 Gigabit Ethernet module with DFC3C (req. X2)
WS-X6908-10G-2T=
C6K 8 port 10 Gigabit Ethernet module with DFC4 (Trustsec) S
Pete Cowen Tue, 04/04/2017 - 01:27
Hi. Did you ever get the WS-X6708-10G-3C= working with a SUP720-3B.
I have a short term fix requirement for 10G into 6500 before refresh to 6708 Sup6T.
Joseph W. Doherty Tue, 04/04/2017 - 06:36
I believe we have 6708 line cards working with both sup720-3Bs and VS-S720s.  The 6708 will not work with a sup2T (and probably not a sup6T either.)
To work with a sup2T, and you need a CFC or DFC4 line card, and the 6708's DFC3C cannot be upgraded or removed.
Pete Cowen Tue, 04/04/2017 - 06:58
Thanks Joseph,
Small typo above, I meant refresh to 6807 chassis with Sup6T so the 6708 cards would be traded in for 6800 16port 10G.
