Play in future does not work
Mar 12th, 2010
I have a DMM with 5.2 release and it is working fine but, the option play in future does not work. It did not open the windows and not showed any thing.
I have tried to run play in future option with some java ( 1.6.0, 1.6.0_01, 1.6.0_04, 1.6.0_07 and 1.6.0_18 ) release but, It have not worked.
What release should I use to run this option?
Thanks and Regards.
Overall Rating: 4 (1 ratings)
azjpiper151 Tue, 03/23/2010 - 16:24
Version 5.2 is not really Java nessary. Upgrade your flash and see if that works better for you. I had the same issue when I was working with the DMD portion of 5.2 and found it was not a Java issue but insted it was a old version of flash that was messing me up. Upgraded Flash 10 and it was all good after that.
JP
max_solovyov Wed, 03/24/2010 - 01:11
Still does not work
Here is the errors list from Java console
2    [AWT-EventQueue-2] ERROR respond.SetApplicationsMarshaller::fromXml  - Cannot init Applications from XML...
java.lang.IllegalArgumentException: Illegal pattern  character 'M'
    at java.text.SimpleDateFormat.translatePattern(Unknown Source)
    at java.text.SimpleDateFormat.applyLocalizedPattern(Unknown Source)
    at com.cisco.dm2bu.ds.client.scheduler.data.ScheduleSimpleDateFormat.parse(ScheduleSimpleDateFormat.java:64)
    at com.cisco.dm2bu.ds.client.scheduler.data.ScheduleSimpleDateFormat.(ScheduleSimpleDateFormat.java:46)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.object.ApplicationMarshaller.createApplications(ApplicationMarshaller.java:66)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.SetApplicationsMarshaller.fromXml(SetApplicationsMarshaller.java:58)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.MarshallerController.fromXml(MarshallerController.java:108)
    at com.cisco.dm2bu.ds.client.scheduler.utils.EventHandling.processGetApplicationsExternalEvent(EventHandling.java:123)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerData(SchedulerApplet.java:239)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerApplet(SchedulerApplet.java:197)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.access$000(SchedulerApplet.java:51)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet$1.run(SchedulerApplet.java:172)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
700  [AWT-EventQueue-2] ERROR respond.InitSetSchedulesMarshaller::fromXml  - Error during XML parsing...
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.InitSetSchedulesMarshaller.initSchedulerDateSettings(InitSetSchedulesMarshaller.java:103)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.InitSetSchedulesMarshaller.fromXml(InitSetSchedulesMarshaller.java:52)
    at com.cisco.dm2bu.ds.client.scheduler.utils.EventHandling.processGetInitSchedulesExternalEvent(EventHandling.java:111)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerData(SchedulerApplet.java:241)
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
    at com.cisco.dm2bu.ds.client.scheduler.gui.baseview.BaseViewPanel.initTopNavigPanel(BaseViewPanel.java:154)
    at com.cisco.dm2bu.ds.client.scheduler.gui.baseview.BaseViewPanel.(BaseViewPanel.java:98)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerGui(SchedulerApplet.java:279)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerApplet(SchedulerApplet.java:200)
dtapia Wed, 03/24/2010 - 13:45
Hi Max,
I found that this issues is present in 5.0.2 version too, If you pc works with WinXP try to do this:
Go to the control panel
  --> double clicl on Regional and language Option
  --> choose :
--------->Standards and formats [English(Unated States]
--------->Location [United States]
Reboot Windows
-> Launch Browser and Point to DMM-DSM and test again
I hope this helps!
max_solovyov Thu, 03/25/2010 - 00:25
I have a windows 7, but i try to change  location. Unfortunately, it does not help.
I found, that on WinXP everything is fine, but on Win7 we have such problems.
vjemin Wed, 04/14/2010 - 03:45
Hi all,
This regional and location changing was very helpfull to me.
I have Windows XP and Windows 7.
I even didn't need to reboot windows. It works after I have change settings.
