Remote access VPN can't connect to internal network
sonitadmin
Trying to configure this using all CLI as I have not had much luck getting these to work with ASDM.  I was able to get the VPN client to connect and to pick up an IP address from the pool I created but now I cannot ping or access anything on the internal network.  I'm sure that I am missing something in my config but I am not 100% sure what it is.  Could someone please take a look at it and let me know if there is something glaringly missing.
Thanks!
slmansfield
Level 4
Level 4
Have you configured access from the internal LAN to your VPN cllient?  The devices on your internal LAN need to be able to reach the VPN client subnet.   HTH
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00809d07de.shtml
