Cisco VPN Client with Windows 7 Home Premium 64 bit
Answered Question
Mar 12th, 2010
I recently purchased a new laptop with Windows 7 Home Premium 64 bit.   I need to connect to an IPSEC VPN for work.  I tried the current VPN client and after reading posts in this group I tried vpnclient-win-msi-5.0.07.0240-k9-BETA.exe.  When I tried to install the Beta I get the following error message:
Error 28011: Windows 64-bit is not supported by Cisco Systems VPN Client 5.0.07.0240.
Any suggestions would be appreciated.
Correct Answer by johnd2310 about 7 years 1 week ago
You need to download the 64bit version. vpnclient-winx64-msi-5.0.07.0240-k9-BETA.exe The version you tried to install is the 32 bit version
John
Overall Rating: 5 (1 ratings)
Correct Answer
johnd2310 Sat, 03/13/2010 - 22:00
  • Silver, 250 points or more
John
gstucky Sun, 03/14/2010 - 08:43
Thanks.  I cant believe I didnt see it when I tried the original download.   Any idea how stable it is?
johnd2310 Mon, 03/15/2010 - 08:56
I have been running it on windows 7 enterpvrise for a while now and i have moved most of my users onto the beta without a problem.
thanks
john
neil.woolloff Tue, 12/21/2010 - 06:13
Greg,
Did you get this installed all ok on Windows7 Home Premium?
I am encountering issues, but all other flavoures, (Enterprise/Professional/Ultimate), are all ok.
I am using the stable release: vpnclient-winx64-msi-5.0.07.0290-k9
The release nores, vpnclient5007.pdf, are not very clear on flavours.
Any thoughts appreciated.
Rgrds,
Neil
njbeachcool Tue, 12/21/2010 - 09:50
I just installed vpnclient-winx64-msi-5.0.07.0290-k9 on Windows 7 64
Home Premium (non upgrade from Vista) as the release notes say and it is working fine.
I have the opposite problem where I have a 64 Bit Windows 7 Professional that installs fine but the GUI hangs on the opening screen and will not continue. I am trying to figure out how to trace what it is in contention with.
Kevin, CISSP
