cannot access the Cisco Unity System Administration.
alis.tommy
Unity Errors
Hi All,
Please help how to add access to unity system adminstration
I've already add the AD account to local administrators group and subscriber with default adminstrative template
but when i use GrantUnityAccess there a error
D:\CommServer>GrantUnityAccess -l
Subscriber                Directory Account
Installer                 IND\Unity Admin
Installer                 IND\Unitysvc
2 items in list
Logfile generated: D:\CommServer\Logs\GrantUAccess_4b99e5cf.txt
-- Operation Succeeded --
D:\CommServer>GrantUnityAccess -u ind\Alis Tommy -s Installer -c 10.10.10.10
Could not get SID for user ind\Alis
The operation completed successfully.
Failed getting SID for NT user Alis.
Logfile generated: D:\CommServer\Logs\GrantUAccess_4b99e98f.txt
-- Operation FAILED --
D:\CommServer>
Please help
Thanks before
Access denied
Your Windows Domain Account  [IND\Alis Tommy] is not associated with a Cisco Unity  Subscriber.
You cannot access the Cisco  Unity System Administration.
Please see  your Cisco Unity system administrator for more details.
Bradford Magnani
It probably doesn't like the space in the display name you're using
(Alis Tommy). Try using your Active Directory alias instead of the
display name:
GrantUnityAccess.exe -u IND\youralias -s EAdmin
Hope that helps,
Brad
