How to ACS 5.0.0.21 Expresss integrate with Active Directory Standar 2003 and authenticate PEAP MSCHAPV2
Mar 13th, 2010
Hi:
My name is Ivan, I have a trouble
I have a ACS 5.0.0.21 express, and i have to integrate with Active Directory (AD)  2003 Standar. I should authenticate the users of the Domain in the LAN with PEAP MSCHPAV2, using the follow:
Cisco WLC 4402 + Cisco ACS 5.0.0.21 + Active Directory
I need to know if i should to install a certificate in the ACS 5.0.0.21 or some agent remote install  in the AD.
I put in the ACS a external database with the AD, and i already select the users on the domain in the ACS Express.
Please could you tell me all the steps to autenticate the users on the Domain using the ACS Express and the Active Directory,
I would like to know wich are the configuration that i have to do in my ACS express to authenticate using PEAP MSCHAPV2
Ivan
