trunk group > busy fxs returning congestion instead of busy
Mar 13th, 2010
We have a 2811 with:
1 ISDN PRI
4 FXS ports
3 SIP Peers (asterisk)
Calls are working fine, calls come in from the PRI and from SIP peers and get routed to the FXS ports
However, when all 4 FXS ports are busy, the 2811 is returning a Congestion on the PRI, and a 500/internal error to the SIP peers.
How can I make this be busy instead?
paolo bevilacqua Sun, 03/14/2010 - 06:39
  • Hall of Fame,
    Founding Member
Which exact IOS are you using ?
jantkowiak2 Fri, 03/19/2010 - 14:23
c2800nm-adventerprisek9_ivs-mz.124-24.T2.bin
figured it out though, I needed the hunt-stop command in the dial-peer
Related Content
