Dynamic reskilling from supervisor desktop
Answered Question
Mar 13th, 2010
Hello.
I saw in a document that it can do dynamic reskilling by administrator or supervisor. Can i asign dynamically the skills to agents from the supervisor desktop and how?
Jose Luis Arango Carvajal
Correct Answer by Aaron Harrison about 7 years 4 months ago
Are you talking UCCX or UCCE?
In UCCX there is no ability to change skills from the Supervisor Desktop, but you can log into AppAdmin as the Supervisor and get a restricted view of AppAdmin which allows you to change skills (as long as you have set the 'Supervisor access to teams' system parameter to allow it).
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Sun, 03/14/2010 - 01:07
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Jose Arango Mon, 03/15/2010 - 11:42
Yeah i talking about UCCX 7.x. Ok then the supervisor can change the skills form web access.
thank you for your answer
