NAC web agent question
Mar 14th, 2010
I need to know when can i use the NAC web agent???  is it used for guests or visitors only????
If i used NAC web agent for guests , can i perform posture assessment for the guest users ( i mean check windows update , AV/AS or certain services)?? or network scanning will be only applied to the guests who are using NAC web agent????
i read the userguide of 4.7.1 of CAM and CAS but i have some conflicts regarding the above topic , so please i need your help.
Faisal Sehbai Sun, 03/14/2010 - 08:42
You can use it for any kind of users (guest/regular) and can do posture assessment, but no remediation. Remediation requires the full agent. The other limitation is that the web agent is only valid on Windows machines and cannot run on Mac/Linux etc.
