May I use same transceiver MGBLH1 for linksys2024 and also for the module WS-4448-GB-SFP ?
Mar 14th, 2010
Hi everybody,
I need to connect 35 nos switches linksys SRW2024 to one switch Cisco Catalyst 4503 - module WS-4448-GB-SFP, with single mode fiber optic.
So my question is, what kind of transceiver can I use to connect the switches? I will use also fiber patch panel, and I need to know also what kind of connectors,and patch cords I need for this one?
I have a few transceivers MGBLH1, this kind may I use also for WS-4448-GB-SFP?
Thanks in advanced for any help from you!
Tom Randstrom Sun, 03/14/2010 - 09:18
  • Gold, 750 points or more
Typically, you cannot use a Linksys SFP modules within a standard Cisco switch due to a software compatibility check between the equipment and the SFP module.
For the Cisco switch, the following compatibility document provides the part numbers for your equipment.
<http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html>
I don't know if the Linksys has the same compatibility check software, but I would assume so.  It also prevents the user from purchasing SFP's from a third-party manufacturer.
Both the Cisco  SFP modules use LC style connectors.
Hope this helps!
