Site-to-site VPN using UDP?
Answered Question
Mar 14th, 2010
Is possible to create a site-to-site VPN when one end is behind a ISP NAT'ed internet connection using a cisco router?
Specifically IPSEC can use UDP? So far I only managed to do this using OpenVPN.
Correct Answer by Federico Coto F... about 6 years 11 months ago
The site-to-site VPN can be established if you're doing NAT.
ISAKMP is established using UDP port 500 and then the encrypted traffic is encapsulated using ESP.
If it's NAT is not a problem.
If you're using PAT, ESP causes problems because ESP has no layer 4 information and therefore cannot be PATed.
If this is the situation, just use NAT-T so that ESP traffic will be encapsulated in UDP port 4500.
This should work with no problems.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Sun, 03/14/2010 - 09:38
Federico.
nunojpg00 Mon, 03/15/2010 - 17:03
PAT, sorry. But you explained for all cases. Wonderfull.
Thank you!
