2811 multiple h323-providers
Hi!
I have a 2811 and two ISP with h323-voice (see scheme at attach). ISP-1 requires use interface0/0 address for voice communication. ISP-2 requires use interface0/1 address for voice communications. 2811 are registered as h323-gateway in UCM with address 192.168.44.5 How can I configure 2811 to use correct VOIP-adress to setup voice communications with each ISP? How to configure h323-gateway to use diffirent interface with multiple h323-peers?
Tommer Catlin Mon, 03/15/2010 - 09:05
  • Green, 3000 points or more
You should be able to use the bind command for each dial peer so it takes the "correct" route.
