use of Sub system number in SS7 network
Mar 15th, 2010
I would like to know the use of SSN in SS7 network.
Also, I have a ICM prerouting scenario, I need to configure my PGW and ICM NIC with a SSN. Please let me know what value i should use in SSN field.
Tommer Catlin Mon, 03/15/2010 - 09:11
Can you post an example?     I have not seen an example of this.   I could mistaken, but I dont think CUCM or gateway will look at this level of the SS7 to handle routing.  I believe its only looking at the transport layers to setup the call and monitor it.  The actual digits dialed or routed happen at a different level.  (all though I could be off on this)
Sorry, I just noticed the PGW.....  I have not worked with this device....  hence my reply probably does not make sense.
Hopefully someone has answers for you.
aravindhanelango Mon, 03/15/2010 - 09:31
Here is the topology,
PGW<-------->ITP<----------->ICM NIC
PGW is connected to cisco ITP (2811 router with special ITP image) via ethernet. ITP is conncted to ICM NIC using V.35 cable. both talk traditional SS7.
