Call Manager components and VLANs
Mar 15th, 2010
my question is about best VLAN distribution of main Call Manager components. I have to setup an infrastructure with:
- 3 CUCM Servers
- 2 Unity Connection Servers
- 6 Gateways Routers
- 2 servers with 4 monitoring software (Unified Provisioning Manager, Unified Operations Manager, Unified Service Monitor, Unified Service Statistics
Manager)
Assuming that i will put IP Phones on separate VLANs, my questions are:
- which is the best VLAN configuration for all these components ? (eg: CUCM and Gateways in same VLAN, ecc...)
- is there any particular rule i must respect to put these appliances in separate VLANs ? I mean, if there is a limitation that force me to put some components on the same VLAN or put other components in different VLANs.
Thank you.
Aaron Harrison Mon, 03/15/2010 - 04:32
I would only split them into separate VLANs if there was a good networking reason to do so - i.e. because the physical topology of the network means that the VLANs (in combination with other things) would improve performance or fault tolerance.
The only exception to this would be if you had a large number of devices on the CCM subnet - the UCOS has a limit of 1024 entries in the ARP table. Since you have your phones in another VLAN, this shouldn't be an issue for you unless this happens to be a large, busy server subnet.
Aaron
