PPP
Answered Question
Mar 15th, 2010
I have a cisco router 18XX series with 2 fastethernet ports,1 console,1 AUX. ISP has dropped 1 ethernet cable to branch office for internet connection, I want to configure a PPPOE on ethernet interface to connect to internet.
Can anybody link me to proper explanation doc's or book, for better troubleshooting and configuration.
Thanks.
Correct Answer by paolo bevilacqua about 7 years 1 month ago
You may need to configure speed and duplex on the interface.
Also
interface FastEthernet0/0
ip nat outside
is not needed. The actual interface is Dialer.
ip route 0.0.0.0 0.0.0.0 Dialer1
Also not needed. Done with ppp command.
Overall Rating: 5 (1 ratings)
thomasandy32 Mon, 03/15/2010 - 13:32
Hello bevila,
I have been to this doc before, I had configured according to the above document instead of atm interface i have 2 Ethernet interface,1 is connecting to internal network and the other I m connecting the ISP link, i want to confirm instead of ATM i have fastethernet Interface connected to ISP link,Will it work ??????
description Connected to ISP Link
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.25
description connected to internal network
encapsulation dot1Q 25
ip address 192.168.25.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1455
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap hostname XXXXXX
ppp chap password  XXXXXXX
ppp pap sent-username XXXXX password 0 XXXXX
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 110 interface Dialer1 overload
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} access-list 110 permit ip any any
dialer-list 1 protocol ip permit
paolo bevilacqua Mon, 03/15/2010 - 13:56
  • Hall of Fame,
    Founding Member
That is what the document is all about.
Use:
mtu 1492
ip tcp adjust-mss 1452
not needed:
ip mtp 1492
dialer persistent
dialer-group 1
Please remember to rate useful posts clicking on the stars below.
thomasandy32 Mon, 03/15/2010 - 14:15
Thanks for ur reply,appreciate
1 more query,
When i connect ISP link to my router the link is up but the protocol is down no LED is blinking on router interface. But when i connect to my laptop  LAN Card the LED glows and the physical connection is UP,
Is i m missing anything in the config's.???
Correct Answer
paolo bevilacqua Mon, 03/15/2010 - 14:52
  • Hall of Fame,
    Founding Member
Also
ip nat outside
