Doubt authentication WLC - WS-SVC-WISM-1-K9
Mar 15th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hello
I have a concern regarding the authentication in my network WLAN, we have a WLC - WS-SVC-WISM-1-K9, which we set up and has a SSID with the WPA parameters policy, WPA Encryption TKIP and Auth Key Mgmt 802.1. x. This authenticates with an ACS server and its time to other external databases. Users connect to the WLAN must be configured in your network card the above parameters, so to deploy a window authentication for the WLAN network service. We want this process to be not so extensive, the WLC can send this configuration to the mobile team and so the user can easily connect
Scott Fella Mon, 03/15/2010 - 18:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I hope i'm understanding this right..... you have a wireless network and an ssid using wpa/tkip enterprise (802.1x).  You have windows clients and want to be able to setup the users without too much trouble.  Well if you are using windows zero config and your user devices are part of the domain, then you can use GPO to push out the wireless profile which will have the ssid and configurations required to connect to the network.  Let me know if im way off here:)
jealbadanp Thu, 03/18/2010 - 12:04
Thank you very much
and if not there GPO, we can make another alternate configuration
Scott Fella Thu, 03/18/2010 - 12:27
  • Hall of Fame,
    2017 Wireless
No problem.... GPO is your best bet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
