Internet link termination on Firewall
Collin Clark Mon, 03/15/2010 - 09:52
Yes it can be done. Pros are easy configuration and less devices to manage. The only Con I can think of is there will be no pre-filtering which isn't a huge deal anyway. Routing is very straightforward. Assume that your ISP is giving you a range of IP's of, with .1 being their device and your default gateway. The command would look like this-
ip route
Hope it helps.
Ganesh Hariharan Sat, 03/20/2010 - 09:19
Hi All,
Can we terminate an internet link with ethernet handoff on a firewall.If yes what are the pros and cons of the routing will be done in this case.
please assit with above queries.
Yes collin is right you can do that and check out the below sample configuration of ASA 5505  configuration with simple default routing.
Hope to Help !!
