03-15-2010 07:45 AM - edited 03-11-2019 10:21 AM
Hi All,
Can we terminate an internet link with ethernet handoff on a firewall.If yes what are the pros and cons of it.how the routing will be done in this case.
please assit with above queries.
thanks
03-15-2010 08:09 AM
Hi All,
thanks
VIcky
Yes you can and the routing would be quite simple ie. you would simply need a default-route on the ASA pointing to the upstream ISP router eg.
ip route 0.0.0.0 0.0.0.0
As for pros and cons. Well routers have more functionality such as a much more fully featured QOS toolset but then if it is Internet connectivity your QOS options are limited anyway. An upstream router can also be used to filter out some of the more general traffic ie. you should not see any private RFC addressing coming from the Internet so you can have a basic acl on the router to filter this out.
But probably the most common reason to use a router is that the handoff is not ethernet which was happened a lot in the past. Nowadays with ethernet becoming more prevalent in WAN as well as LAN it is perfectly acceptable to terminate your connection directly to the ASA.
Jon
03-15-2010 11:28 AM
thank you very much for your quick help
