Need process info "MFI LFD Stats Pr" on VS-s720-10G with SXI3 code
Answered Question
Mar 15th, 2010
Does anyone know what MFI LFD Stats process do??One my client has high CPU on the 6500 switch doing MPLS VPN
6500sw#show proc cpu sort
CPU utilization for five seconds: 99%/80%; one minute: 93%; five minutes: 92%
  PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
555   399550384   1184091     337458 18.23%  7.44%  7.05%   0 MFI LFD Stats Pr
I understand high CPU is due to interrupt processing on RP in this case. Does MFI LFD Stats Pr process involved in any LDP packets processing??
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Krunal,
MFI should stand for MPLS Forwarding Infrastructure that has been introduced in 12.2(33)SXH and 12.4(20)T so yes it is related to MPLS.
see
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_lsc_removed.html
>> The MFI, which manages MPLS data structures used  for forwarding, replaces the Label Forwarding Information Base (LFIB).
what exactly the process MFI LFD Stats Pr
does is difficult to say it looks like related to statistics of label forwarding activity.
this process is taking 7% of cpu but I see that  your sysrem is full loaded.
80% of cpu is used by cpu interrupts probably meaning  that a big quota of traffic is processed by  main cpu.
Hope  to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 03/15/2010 - 14:16
Hello Krunal,
see
Hope  to help
Giuseppe
krunal_shah Tue, 03/16/2010 - 06:06
"MFI LFD" is an acronym for "MPLS Forwarding Infrastructure, Label Forwarding Database".
High CPU was due to routing loop, a prticular route did not get progrmmed into hardware.
Eduard Gheorghiu Wed, 08/01/2012 - 00:43
I know that the question is answered but I have a case with a VSS which uses a lot of the primary SP for the MFI LFD Stats Process although the box has no mpls enabled. Why this process would be used?
Thanks, kind regards,
Eduard
vss#remote command switch-id 1 module 5 show process cpu sort
CPU utilization for five seconds: 40%/4%; one minute: 28%; five minutes: 28%
196  4003994652 415167190       9644 27.61% 14.20% 13.51%   0 MFI LFD Stats Pr
127  31901132483381077946          0  2.38%  2.90%  2.87%   0 DiagCard8/-1
vss-bi0514#sh ver | i ima
System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI1.bin"
vss-bi0514#show mpls int
% Invalid input detected at '^' marker.
