03-15-2010 09:23 AM - edited 03-11-2019 10:21 AM
We provide open Internet access to users. The only current security device on the network is a Proxy Server to prevent access to certain websites. Our network is simple:
RF Antennae --> RF Modem --> Cisco 3845(NAT) --> L3 Switches (Core Services) --> L3/L2 Switches --> Users.
Where should I put the ASA 5550 and why? The customer requires this device to prevent traffic initiated from outside the network. From reading the documentation, using the default security levels would be fine and no additional ACL's would be required. I do plan on using the ASA to block any websites or networks that the Proxy can't.
Thanks in advance,
Damien
03-15-2010 09:38 AM
You can place the firewall between 3845 router and L3 switches(core) .You can configure NAT in Firewall itself.
Make the interface which is connected to 3845 router as outside and the make the security level set to 0.
Configure the interface which is connected to core switch as inside and the security level will be 100.
As you might be aware that, by default in PIX/ASA from low security level(outside) to high security level (inside) all the traffic will be blocked.
So you can allow the necessary traffic from outside to insdie by configuring ACL and apply that ACL in outside interface.
Karuppu
03-15-2010 10:40 PM
In addition to what has been pointed already by Karuppuchamy Malaiyandi I would like to inform you that ASA cannot do deep packet inspection.
This means that ASA can not filter websites using HTTPS. All the HTTP websites can be filtered using the Modular Polidy Framework on the box (See sample config below).
In order to do advanced filtering of websites you may have to use Security modules, or 3rd party Webfilters for e.g. Websense
Sample config to block www.yahoo.com and www.google.com sites for any user :
regex url1 "mail.yahoo.com"
regex url2 "mail.google.com"
class-map type regex match-any urlreg
match regex url1
match regex url2
class-map type inspect http match-all http_url_policy
match request header host regex class urlreg
access-l http permit tcp any any eq 80
class-map acl
match access-list http
policy-map type inspect http http_policy
parameters
class http_url_policy
drop-connection
policy-map httpdrop
class acl
service-policy httpdrop interface outside
Feel free to read more below
ASA/PIX 8.x: Block Certain Websites (URLs) Using Regular Expressions With MPF Configuration Example:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
Vijaya
