renaming objects in UCS manager
Answered Question
Mar 15th, 2010
How do I rename objects in UCSM - things like service profiles,
templates, policies, etc. I can't find anything in the GUI or CLI to do this.
Thanks.
Correct Answer by Robert Burns about 7 years 1 week ago
Mark,
With the current revision of code its not possible to rename Service Profile or any templates.  This is a future enhancement in the pipe, but there's no committed date at this point.
Robert
Overall Rating: 5 (1 ratings)
Correct Answer
Robert Burns Mon, 03/15/2010 - 14:00
  • Cisco Employee,
Mark,
Robert
m.heil Wed, 03/17/2010 - 12:13
Mark,
Robert is correct.  When we implemented we found the lack of renaming a frustration.  Our approach ended up defining a consistent naming convention and following it.  When we named something "incorrect" and it is important enough to you, the procedure is to delete the object and recreate it.
I recall being told that this is not a simple thing to change and probably will take a while before it is changed.  Take care.
Mike Heil
www.healthitguy.com
v-erlill@ Fri, 08/31/2012 - 14:31
This thread hasn't been updated since Mar 17, 2010. Is it still not possible to rename Service Profile or templates?
Robert Burns Sat, 09/01/2012 - 16:27
  • Cisco Employee,
Eric,
Service Profile renaming is a new feature coming in the next major release of UCSM  2.1.  It's tentatively scheduled for Q4 2012.
Other object behavior in UCSM will remain the same.
Robert
Related Content
