CME Default Config Query
Mar 15th, 2010
  • Silver, 250 points or more
We have remote site gateway connected over IPSEC VPN. It's CME box with ISDN 2 BRI for voice. We're using H323 dial-peers to make call over the IP WAN. There's a couple of commands for sip which I understand are required for CUE/MWI*. This is all working no probs.
The gateway is listening on SIP and H323 ports on the external facing interface and i've been asked to shut these off. ACL is the easy way out but I was looking at this config and wanted to know if any parts are required?
voice  service voip
  allow-connections h323 to sip
  allow-connections sip to h323
  allow-connections sip to sip
  redirect ip2ip
  fax protocol cisco
  h323
*afaik the two following commands are required for CUE and MWI:
session protocol sipv2
dtmf-relay sip-notify
thanks
Ajaz
paolo bevilacqua Mon, 03/15/2010 - 10:39
  • Hall of Fame,
    Founding Member
Yes, use ACL and eliminate anything not needed.
