Compatibility between VS-S720-10G and WS-SUP720-3B?
Answered Question
Mar 15th, 2010
Hi everybody.
We are planning a migration from two 6509-E chassis with a WS-SUP720-3B each, to the same two chassis with a VS-S720-10G each, to add VSS support to the system, and I have a couple of questions:
I've been looking for some information about a possible "hot" migration with no risk of losing connection, by having a common time with the two supervisor cards living together (one of each model).  But the only doc I've found doesn't mention anything about it (http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c74c.shtml. That would be the ideal solution, of course, but no info. about how to do it.
If that's not possible, I'd like to know if there could have some problem in the step of changing the supervisor model, as it's supposed we would have to remove the WS-SUP720-3B and then insert the VS-S720-10G with a complex configuration installed on the systems.
Thanks in advance.
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Acotelcom,
you cannot plug the new supervisor in another slot and expect the two to become an SSO pair they are different.
There are reports of attempts to do this with a Sup 720 3B with increased memory with a Sup 720 2BXL.
You will need to ask for a maintanance interval.
The configuration file should be likely similar to the current one.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 03/15/2010 - 10:31
Hello Acotelcom,
Hope to help
Giuseppe
Related Content
