Reinstall Subscriber
j.huizinga
Level 6
Level 6
I have the following.
Cluster 5.1, but original install DVD is 5.0.
Now I want to reinstall the sub, but the pub is on 5.1 and the install DVD is 5.0
I do have the Upgrade patch 5.1
Can I install the sub using 5.0 and then upgrade to 5.1 and resync the database?
Or do I need now 5.1 install DVD?
Any idea?
Jan
Aaron Harrison
You should be able to boot from the 5.0 media, and will then be prompted whether you wish to install a patch during the install. Point this at your upgrade file on an SFTP server.
This works for all the versions I can remember, hopefully it wasn't something introduced after the 5.0 release!
Boot it up, you should find out pretty quick.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Yeah, you are right, never tried it though.
I shall see tomorrow,
Jan
