capture circular-buffering to syslog server
Mar 15th, 2010
I'm running 8.0.5 and want to setup capture with “circular-buffer” and log it to my syslog server. Can I do this and if so, how?
Will this have a huge effect on my cpu/mem assuming default buffer at 512?
Kureli Sankar Mon, 03/15/2010 - 20:34
If you want to capture your inside host's internet browsing traffic, you can issue the following with a circular-buffer command
cap capin int inside match tcp host any eq 80 circular-buffer buffer 10000000
This will create a 10MB capture file and continue collecting fresh packets after the 10MB buffer gets full.
I am not sure what you mean by send it to syslog server.
You have to issue "sh cap capin" or save the capture using tftp or http
capture command reference:
