Converting Firewall configs to ASA 5540
Mar 15th, 2010
I have several Secure Computing Sidewinder G2 Firewalls that we are replacing with ASA 5540's Is there a tool that can convert the configs?
Anything even user supported, This is turning into a year long task.
vilaxmi Mon, 03/15/2010 - 22:16
Though we do have a specific tool to convert PIX configuration to ASA but, there is none to convert config from a third party firewall to ASA platform.
As this may get very deatiled for the forum, I would suggest you to open a TAC case, and give your exact config requirements to the CSE.
They will configure the box for you.
Vijaya
