Cisco Wireless LAN Controller 4402 under Cisco Works RME 4.0?
Answered Question
Mar 15th, 2010
I am trying to manage a Cisco 4402 using non-default snmp communities from Cisco Works RME 4.0.  RME Credential Verification fails with “Device Not Supported” recorded against selected option; however, the controller does respond to snmp queries.  The 4402 has snmpv1 through snmpv3 enabled; and the snmp communities are associated with the correct client IP.  Is the WLC only responsive to snmp from the WLS and should the box be manageable via it’s management interface.  ICMP and telnet to the WLC from RME works OK.
Advice and Guidance would be greatly appreciated.
Correct Answer by Scott Fella about 7 years 2 months ago
What firmware version are on the WLC's..... minimum is 5.0.148 per the RME Table.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.5/device_support/table/RME405.html
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Mon, 03/15/2010 - 19:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott Fella Tue, 03/16/2010 - 05:09
  • Hall of Fame,
    2017 Wireless
Don't upgrade to 5.x if I were you... stick with what you have or upgrade to Cisco's gold code 4.2.207.0.  But that won't help you with the Cisco Works issue.  The latest 6.x is better than 5.x, but is still new and you will be going from lwapp to capwap:)
Trending Topics - Security & Network
