High CPU On Cisco 837 Router
Mar 15th, 2010
  • Blue, 1500 points or more
hi experts,
i checked there's a high CPU usage on this router but logs showed no indication on which process took most of the CPU. we're running site-to-site VPN on this router. not sure if this router can handle or support this feature. i'm also thinking this might be an IOS bug. kindly advise. thanks!
ROUTER#sh proc cpu
CPU utilization for five seconds: 100%/100%; one minute: 100%; five minutes: 100%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           0      1245          0  0.00%  0.00%  0.00%   0 Load Meter
   3          52       639         81  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
   4         168       183        918  0.00%  0.00%  0.00%   2 Virtual Exec
   5      108704      5856      18562  0.00%  0.00%  0.00%   0 Check heaps
   6           0         1          0  0.00%  0.00%  0.00%   0 Pool Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   9           0         1          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  10         140       305        459  0.00%  0.00%  0.00%   0 ARP Input
  11           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  12           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  13           8         2       4000  0.00%  0.00%  0.00%   0 Entity MIB API
  14           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  15           0      6213          0  0.00%  0.00%  0.00%   0 GraphIt
  16           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  17           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  18          32      1280         25  0.00%  0.00%  0.00%   0 Net Background
  19           0        17          0  0.00%  0.00%  0.00%   0 Logger
  20           8      6212          1  0.00%  0.00%  0.00%   0 TTY Background
  21          16      6222          2  0.00%  0.00%  0.00%   0 Per-Second Jobs
  22          24     19901          1  0.00%  0.00%  0.00%   0 LED Timers
  23           0         2          0  0.00%  0.00%  0.00%   0 AUX
  24         504      2499        201  0.00%  0.00%  0.00%   0 ATM Periodic
  25           4         6        666  0.00%  0.00%  0.00%   0 ATM ARP INPUT
  26           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  27           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  28        2424        11     220363  0.00%  0.00%  0.00%   0 AAL Coalesce
  29          32       364         87  0.00%  0.00%  0.00%   0 Net Input
  30           0      1246          0  0.00%  0.00%  0.00%   0 Compute load avg
  31        2476       105      23580  0.00%  0.00%  0.00%   0 Per-minute Jobs
  32         336      3480         96  0.00%  0.00%  0.00%   0 DSL State Machin
  33           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
  34           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  35           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  36           4         2       2000  0.00%  0.00%  0.00%   0 AAA Dictionary R
  37        5600      6666        840  0.00%  0.00%  0.00%   0 IP Input
  38           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  40           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  41           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  42           0         3          0  0.00%  0.00%  0.00%   0 PPPOE discovery
  43         128    381655          0  0.00%  0.00%  0.00%   0 PPPOE background
  44           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  45           0       831          0  0.00%  0.00%  0.00%   0 SSS Test Client
  46          52       137        379  0.00%  0.00%  0.00%   0 IP Background
  47          20       115        173  0.00%  0.00%  0.00%   0 IP RIB Update
  48           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  49           4         2       2000  0.00%  0.00%  0.00%   0 PPP IPCP
  50           0        18          0  0.00%  0.00%  0.00%   0 TCP Timer
  51           4         3       1333  0.00%  0.00%  0.00%   0 TCP Protocols
  52           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  53          48        40       1200  0.00%  0.00%  0.00%   0 DHCPD Receive
  54           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  55           0         2          0  0.00%  0.00%  0.00%   0 HTTP CORE
  56           0       104          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  57           8       110         72  0.00%  0.00%  0.00%   0 Adj Manager
  58           4         2       2000  0.00%  0.00%  0.00%   0 PPP Bind
  59           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
  60           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  61           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  62           0         2          0  0.00%  0.00%  0.00%   0 ILMI Input
  63           0         2          0  0.00%  0.00%  0.00%   0 ILMI Request
  64           0         2          0  0.00%  0.00%  0.00%   0 ILMI Response
  65         188      3088         60  0.00%  0.00%  0.00%   0 ILMI Timer Proce
  66          44         4      11000  0.00%  0.00%  0.00%   0 ATM PVC Discover
  67           0         1          0  0.00%  0.00%  0.00%   0 Inspect Timer
  68          20       105        190  0.00%  0.00%  0.00%   0 URL filter proc
  69           0         1          0  0.00%  0.00%  0.00%   0 Authentication P
  70           0         1          0  0.00%  0.00%  0.00%   0 IDS Timer
  71           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
  72           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
  73           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
  74           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
  75           0         2          0  0.00%  0.00%  0.00%   0 Crypto Support
  76           0         3          0  0.00%  0.00%  0.00%   0 Crypto CA
  77           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
  78           8       103         77  0.00%  0.00%  0.00%   0 Crypto ACL
  79       29748      3222       9232  0.00%  0.00%  0.00%   0 Crypto IKMP
  80        2296       207      11091  0.00%  0.00%  0.00%   0 IPSEC key engine
  81           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
  82           0         1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
  83        4548      2845       1598  0.00%  0.00%  0.00%   0 Encrypt Proc
  84           0         4          0  0.00%  0.00%  0.00%   0 Key Proc
  85           4         2       2000  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
  86           0         2          0  0.00%  0.00%  0.00%   0 IpSecMibTopN
  87           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
  88           0       104          0  0.00%  0.00%  0.00%   0 SAA Event Proces
  89         248      2188        113  0.00%  0.00%  0.00%   0 IP NAT Ager
  90          36        82        439  0.00%  0.00%  0.00%   0 IP SNMP
  91          24        41        585  0.00%  0.00%  0.00%   0 PDU DISPATCHER
  92         132        43       3069  0.00%  0.00%  0.00%   0 SNMP ENGINE
  93           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
  94           0        52          0  0.00%  0.00%  0.00%   0 DHCPD Timer
  95           0      1753          0  0.00%  0.00%  0.00%   0 DHCPD Database
ROUTER#sh ver
IOS (tm) C837 Software (C837-K9O3Y6-M), Version 12.2(11)YV, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to technology version 12.2(13.1u)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 20-Jan-03 22:39 by ealyon
Image text-base: 0x800131E8, data-base: 0x80A2C6C8
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
ROM: C837 Software (C837-K9O3Y6-M), Version 12.2(11)YV, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
KORCHINA-SG-GW uptime is 1 hour, 46 minutes
System image file is "flash:c837-k9o3y6-mz.122-11.YV.bin"
CISCO C837 (MPC857DSL) processor (revision 0x200) with 29492K/3276K bytes of memory.
Processor board ID AMB070903BQ (479383020), with hardware revision 0000
CPU rev number 7
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Overall Rating: 3 (1 ratings)
Leo Laohoo Mon, 03/15/2010 - 17:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
IOS vulnerable to IOS Heap-based Overflow Vulnerability in System Timers exploitation.  Migrate to 12.3(14)T4 or later.
http://www.cisco.com/en/US/partner/products/products_security_advisory09186a008055ef31.shtml
