IOS Support for IP SLA
Answered Question
Mar 15th, 2010
hi experts,
i've got an Cisco 1841 and 2611XM series routers that doesn't support IP SLA. due to my Cisco.com login account, I can't access the Software Advisor tool to suggest the recommended IOS to support this feature. would greatly appreciate if someone could advise me the necessary IOS on both routers to support IP SLA feature. thanks in advance!
1841#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SO
FTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SG uptime is 3 days, 16 hours, 59 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 97280K/33792K bytes of memory.
Processor board ID FHK124628JE
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
2611#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(6b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 19-May-04 23:04 by dchih
Image text-base: 0x80008098, data-base: 0x819B42DC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
SG uptime is 23 hours, 27 minutes
System image file is "flash:c2600-is-mz.123-6b.bin"
cisco 2611XM (MPC860P) processor (revision 0x300) with 98304K/32768K bytes of memory.
Processor board ID JAE0817EFUF (594279078)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
hi ganesh,
thanks! i would like to check if these IOSs can support IP SLA. i'm particular setting up IP SLA to monitor UDP jitter.
c1841-advipservicesk9-mz.124-9.T3
c1841-advipservicesk9-mz.124-9.T7
c1841-advipservicesk9-mz.124-24.T
c2600-adventerprisek9-mz.124-21a
Following ios
train are having Common Features in all the images that is IP SLAs - UDP Jitter Operation.
and for
IP SLAs - UDP Jitter Operation is also supported in above ios.
Hope to help !!
Ganesh.H
hi experts,
1841#sh ver
FTWARE (fc2)
2611#sh ver
Bridging software.
Following are the ios which are supported for following IP SLA commands in your routers1800 and 2600
15.0(1)M c181x-advipservicesk9-mz.15.0-1.M
12.4(11)XW10 c181x-advipservicesk9-mz.12.4-11.XW10
12.4(11)XJ4 c181x-advipservicesk9-mz.12.4-11.XJ4
12.4(24)T2 c181x-advipservicesk9-mz.12.4-24.T2
12.4(11)XJ4 c2600-entservicesk9-mz.12.4-11.XJ4
12.4(15)T11 c2600-entservicesk9-mz.12.4-15.T11
IP SLAs - ICMP Jitter Operation
IP SLAs - ATM/Frame-Relay Thresholds
IP SLAs - Application Performance Monitor (APM)
IP SLAs - DHCP Operation
IP SLAs - DNS Operation
IP SLAs - Distribution of Statistics
IP SLAs - FTP Operation
IP SLAs - Frame Relay Interfaces
IP SLAs - Frame Relay Operation
IP SLAs - HTTP Operation
IP SLAs - History Statistics
IP SLAs - ICMP Echo Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - Multi Operation Scheduler
IP SLAs - One Way Measurement
IP SLAs - Path Jitter Operation
IP SLAs - Reaction Threshold
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - Scheduler
IP SLAs - TCP Connect Operation
IP SLAs - UDP Based VoIP Operation
IP SLAs - UDP Echo Operation
IP SLAs - VoIP Threshold Traps
IP SLAs Additional Threshold Traps
IP SLAs Random Scheduler
IP SLAs Sub-millisecond Accuracy Improvements
IP SLAs VoIP Call Setup (Post Dial Delay) Monitoring
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Overall Rating: 5 (2 ratings)
Correct Answer
Ganesh Hariharan Mon, 03/15/2010 - 23:42
hi experts,
1841#sh ver
FTWARE (fc2)
2611#sh ver
Bridging software.
IP SLAs - Scheduler
Hope to Help !!
Ganesh.H
johnlloyd_13 Tue, 03/16/2010 - 01:40
hi ganesh,
Correct Answer
Ganesh Hariharan Tue, 03/16/2010 - 04:15
hi ganesh,
Following ios
and for
Hope to help !!
Ganesh.H
