Cable distance
Answered Question
Mar 16th, 2010
i hope someone will be able to help me out. I'm trying to deploy an AP with a max range from the switch >100m. The question is can i pull a 100m cable from the switch to the power injector and another 100m from the power injector to the AP?
switch --------(100m cable)------------ pwrinj3 --------(100m cable)------------ AP
I hope i actually explain this clearly. thanks for the help in advance.
Correct Answer by kirchhoffpolska about 7 years 3 months ago
Yes you can
I use such configuration. About 150 m whole distance and it works with no problem
Overall Rating: 4 (2 ratings)
Scott Fella Tue, 03/16/2010 - 05:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Correct Answer
kirchhoffpolska Tue, 03/16/2010 - 08:53
Yes you can
